Key fob battrie change transit 2006
Postby Eastwater » Sat Feb 25, 2012 9:58 pm
Hi there is there a way for me to change the battrie in my key fob without having to go to a ford dealer ?
I only have one key and the battrie is dead . I managed to get the fob open to revile the battrie and had it tested itvwas dead . I am unable to work out how to get it out to change it ,it looks like ford have put it in in such a way that Joe public cannot change it themselves .
Is there any way I can do it myself ?
Many thanks eastwater
Eastwater
Re: Key fob battrie change transit 2006
Postby motorman116 » Sat Feb 25, 2012 10:05 pm
If its the Blue key, then I dont think that you can change the battery, as they are the rechargable type, that charge when the key is in the ignition.......
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby Eastwater » Sat Feb 25, 2012 10:31 pm
Well I never so is any way of telling if it's a battrie problem ? Or if it's the central locking that's at fault .
Yes it's a blue fob . I am surprised you can recharge them
Thanks eastwater
Eastwater
Postby Herts » Sat Feb 25, 2012 10:45 pm
You could have a duff battery under your seat, the front one.
Andy
MK7 - 2.4 RWD/HR/LWB 3.5T 140HP (BIG BOYS TOY!)
Number 1 Emergency Call out Engineer!!!
http://www.hertsplumbinganddrainage.co.uk
Herts
Postby Eastwater » Sat Feb 25, 2012 10:55 pm
Herts wrote:You could have a duff battery under your seat, the front one.
Andy
Hi andy please can you explain ?
Thanks eastwater
Eastwater
Postby Backbone of Britain » Sat Feb 25, 2012 11:10 pm
There was problems with some of the earlier blue fobs as they were faulty and didn't charge. You may be lucky and Ford may change it for you or you may have to bite the bullet and buy a new fob.
2006 Mk6 115 T350 LWB Highroof
2008 Mk7 115 T350 LX LWB Highroof
Backbone of Britain
Postby Herts » Sat Feb 25, 2012 11:52 pm
Do you have 2 batteries under you seat?
The rear battery starts the van and runs the hazzard lights.
The front battery does everything else.
I noticed my central looking wouldn't work one day and just opened the door with the key, I had my batteries tested and the front battery was not holding a charge, new battery fitted...... all ok.
Andy
Herts
Postby Eastwater » Sun Feb 26, 2012 12:17 pm
Well this morning I am back at the place that's doing the conversion . They are checking the wires found one that had been hit but even after fixing that still no luck .
I had a look under the front seat yess there is a battrie I am hoping to find someone this morning thats got a testing machine to see if it's holding charge .
With the key fob I now don't think it's the battrie in it as I am able to press it a couple neters away from the van and it gives a toot of the horn and lights flash so me thinks if the battrie were dead in the fob it would do nothing when pressed a couple of meters from the van
Do you think that I an right in thinking this ?
Thanks eastwater
Eastwater
Postby motorman116 » Sun Feb 26, 2012 12:25 pm
Is it tooting the horn with all the doors closed, if so you have a problem with one of the doors or door wiring, as its sensing that a door is open
motorman116
Postby Eastwater » Sun Feb 26, 2012 1:07 pm
Yess it's gives 1 hoot with all the doors closed what ever I try to do
Eastwater
Eastwater
Postby Eastwater » Sun Feb 26, 2012 8:31 pm
Thanks for all your help it's all fixed now .they found the fault a wire had been drilled through a wire when doing the insulating and the fuse had blown .
They were great it took them a couple of hours to sort that part and it's all better now I have now just got to glue the fob back together now
Thanks for all your replys
Eastwater :D
Eastwater
Postby taz666 » Sun Feb 26, 2012 8:33 pm
ive had this b4, do the interior lights work?? the central locking runs through 2 fuses and if either is blown then it will beep the horn and not lock, ah you beat me to it lol
taz666
Ford Technician
Postby Benimar » Sat Sep 24, 2016 10:03 pm
hi is there a way of charging the key while not in the tranny as my motor is stored at a motorhome storage facility and i go down every 3 months to fire her up and have to unlock using the key as the remote does nothing once motor has been run for about 15 mins the fob then works ok hence the reason i ask if theres a way of charging at home
Ray
Benimar
Postby ake » Sun Sep 25, 2016 10:17 am
Benimar wrote:hi is there a way of charging the key while not in the tranny as my motor is stored at a motorhome storage facility and i go down every 3 months to fire her up and have to unlock using the key as the remote does nothing once motor has been run for about 15 mins the fob then works ok hence the reason i ask if theres a way of charging at home
Ray
This could be the van battery at fault rather than the fob
I keep our spare keys in the office and I've seen them open a van after being sat in the drawer untouched for 3 years!
