how to find out what type of diesel pump is fitted
Postby transitsonly » Wed Jun 13, 2012 8:25 pm
hi guys, i need a new timing solenoid but i don't know what type of diesel pump i have, please can anyone help, thanks Tony
transitsonly
Re: how to find out what type of diesel pump is fitted
Postby ake » Wed Jun 13, 2012 8:27 pm
What van, what age, what engine and output?
Everyone is entitled to my opinion
Ford Transit 125ps 260 Trend
Ford Transit 130ps 350 Chausson Flash 03
Postby MinorMatt » Wed Jun 13, 2012 8:29 pm
Or just show us a picture of it ;)
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tape.....
Postby taz666 » Wed Jun 13, 2012 9:04 pm
im guessing that as it needs a new timing soleniod its a mk6 transit and if its a di it doent matter if its a vp30 or vp44 the timing soleniod is the same part
taz666
Ford Technician
Postby transitsonly » Fri Jun 15, 2012 9:49 am
thanks you for your replies. yes it is a mk6 2.0 2002. i'm not sure what output means but i will try to find out. i can't believe that i told staines diesels that it's the timing solenoid & they still tell me i need a new pump. they told me that you can't get the timing solenoid. but i have found one on ebay from transit parts for £100. so thats what i'm going to do. just got to make sure my pump is a bosh.
transitsonly
Postby MinorMatt » Fri Jun 15, 2012 10:08 am
Staines Diesels used to be ok :?
But if they are trying to fob you off saying that you can't get a timing solenoid look elsewhere! Its a common fault and they should know better!
Postby transitsonly » Fri Jun 15, 2012 6:42 pm
yeah i have looked elsewhere & my brothers mechanic said he will do it for £80. thanks for your replies & i will let you know how i get on, kind regards Tony
transitsonly
Postby taz666 » Fri Jun 15, 2012 8:13 pm
transitsonly wrote:thanks you for your replies. yes it is a mk6 2.0 2002. i'm not sure what output means but i will try to find out. i can't believe that i told staines diesels that it's the timing solenoid & they still tell me i need a new pump. they told me that you can't get the timing solenoid. but i have found one on ebay from transit parts for £100. so thats what i'm going to do. just got to make sure my pump is a bosh.
it doesnt matter what power output it is, if its a di then the timing solenoid is the same whether its a 75ps fwd or a 125 ps rwd, oh and as its fwd it may be easier to pull the whole front off as it will make it easier to get the soleniod out
taz666
Ford Technician
