speedo calibration
speedo calibration
Postby Telford Transit » Mon Jun 18, 2012 10:28 pm
Hoping one of the ford techs can tell me if the speedo in a 2005 2.4 can be re-calibrated?
I have converted a 135 tdci to a 90ps tddi but kept the 6 speed box/axle and the speedo is miles out
cheers :D
Telford Transit
Registered Trader
Registered Trader
Re: speedo calibration
Postby taz666 » Tue Jun 19, 2012 7:35 pm
if its got the same gearbox and axle then should be the same and if its got abs the speed is sourced through the abs
taz666
Ford Technician
Postby darkbluevanman » Tue Jun 19, 2012 9:43 pm
As above?... maybe it was out before, maybe it's got lazy.... probably a trim in the clocks to adjust the reading... all speedo's read fast!
darkbluevanman
Postby Telford Transit » Wed Jun 20, 2012 10:32 am
Speedo reads through abs?? Not on a 2005, it reads from the speedo sensor on the gearbox
speedo usually reads high but not 85mph whilst doing 20mph
its running the six speed tdci box through the tddi loom/ecu
speedo needs calibrating much the same way as a tachograph would be calibrated when installed
just need to know if that is possible,cant get a straight answer out of main dealer
Telford Transit
Registered Trader
Registered Trader
Postby Altransit » Wed Jun 20, 2012 10:34 am
MartynX (Vantuner) may be able to help, give him a ring :idea:
Postby martynx » Fri Jun 22, 2012 8:35 pm
With such a big difference you either have a very different feed signal from the new set ups speed sensor going into the new 90 ECU or the rev counter in the clocks differs.. only way i can think of of testing whats causing it is measure a 135's speed signal from the gearbox & compare it with a 90's one... on older tddi clocks you can swap in other rev counters very easily, not sure on your digi dash model though if thats poss
Theres no gross calibration option in the ECU , like selecting 90/100/135ps etc but you can fine tune by changing specified diff ratio or tyre size.... :)
for egr/dpf deletes, power tuning, updates,cloning,speed limiter removal,cruise control, euro 3/4/5/6 limiters & key's !
martynx
Postby Boler90 » Mon Mar 13, 2017 1:06 am
Hi old post but was this problem ever sold iv just bought a 2006 mk6 125 bhp wich somebody has fitted a 135 6 speed gearbox to and I'm having exact same problem speedo reads around 100 mph when actual speed is about 30 mph
Boler90
Postby martynx » Mon Mar 13, 2017 7:25 pm
Boler90 wrote:Hi old post but was this problem ever sold iv just bought a 2006 mk6 125 bhp wich somebody has fitted a 135 6 speed gearbox to and I'm having exact same problem speedo reads around 100 mph when actual speed is about 30 mph
What is the reg number ?
martynx
Postby martynx » Sat Apr 01, 2017 5:43 pm
I know where the calculation factors are in TDDI ecu' s so it may be poss to adjust such a massive difference, need to try to see if it will accept it,
Sent from my SM-G900F using Tapatalk
martynx
Postby ake » Sun Apr 02, 2017 11:18 am
If the van has abs, unplug the gearbox sensor, it's been on here before, and that fixed it!
Postby Boler90 » Sun Apr 02, 2017 3:48 pm
Hi thanks iv just been out and unplugged the sensor this results in the speedo not working at all..
Anything else I could try
Boler90
Postby GeeJayent » Sat Jul 22, 2017 10:20 pm
Hi all, any updates on this fault?
I have just had a 6 speed box conversion done on 125 tddi 2005 and speedo is reading about 3 times what it ought to.
I don't think abs is fitted but will find out today hopefully
Box came from a 135 tdci engine. Not sure if that makes a difference
GeeJayent
Postby martynx » Tue Jul 25, 2017 2:40 pm
- The gearbox speed sensor goes to the engine ECU, then there is some calculation then the signal goes to the clocks & if alls well the speedo reads about right albeit + a few % for legal reasons. I think the calculation involves axle ratio,tyre size, & number of teeth of gearbox sensor wheel. The number of teeth bit is a guess based on Euro 5 Transits definitely having a setting for number of teeth. I have documentation for Euro 4 & 5 ECU's but nothing exists for the euro 3 so i for one don't where the number of teeth setting is.
I have tried different tyres sixes & axle ratios including up to 20:1 & 25:1 & the speedo readings are out still then the speedo cuts out or worse the engine loses power.
As far as i know (as i did my mods by post), the above results were achieved using a TDDI speed sensor, as the number of wires & plug differs from TDCI to TDDI . one has 2 & one has 3 wires.
There's no option to use a different engine ECU as they are totally different.
Maybe someone who makes gadgets for japanese import cars could make something for the speedo itself , or just someone who understands how they work could put a resistor or something in the right place. :?:
martynx
