any ideas from anyone
If different leafs from standard from what van / pick-up should I be looking for?
The front coil springs will also need replacing as they only have about 1.5 - 2 inch travel and then hit the stops
MinorMatt wrote:I've got a pair off a mk5 tourneo... (used)
jay wrote:120 springs are apparently so my scrap yard say as 100tourneo springs both are 3 leaf springs..dont forget the U bolts as sods law they will snap or be wrong size to your curent springs.
And my 120 dont droop at the back end even when loaded same as you as I am soon in the process of doing a bulkhead like you have done..
AndyG wrote:jay wrote:120 springs are apparently so my scrap yard say as 100tourneo springs both are 3 leaf springs..dont forget the U bolts as sods law they will snap or be wrong size to your curent springs.
And my 120 dont droop at the back end even when loaded same as you as I am soon in the process of doing a bulkhead like you have done..MinorMatt wrote:I've got a pair off a mk5 tourneo... (used)
Tourneo springs are "100" and are normally "High Centre of Gravity" AND "Soft Ride" too![]()
AndyG wrote:HCG springs tend to make the vehicle sit higher off the road and all of these Transits are fitted with a front anti roll bar as standard![]()
And yes, I am saying that 100 springs will not be suitable for what you want, especially as your Transit is a 120 anyway![]()
Put a full load in the back of any genuine Transit 80 or 100 and the van will "speedboat"![]()
Put a full load in the back of a 120 and all it does is level out
