Codes p0149 and p1564
Postby Jonesyscoob » Sun Sep 02, 2012 1:21 pm
Any help as to what these mean,van runs but has a rattle after fuel pump replacement 3 weeks ago
Jonesyscoob
Re: Codes p0149 and p1564
Postby blue estate » Sun Sep 02, 2012 1:24 pm
What van is it ? Age engine size ?
72plt MG 5 ev estate Battery car
blue estate
Postby furnitureman » Sun Sep 02, 2012 1:37 pm
Jonesyscoob wrote:Any help as to what these mean,van runs but has a rattle after fuel pump replacement 3 weeks ago
I posted nearly all the codes in the how to section hope this helps
MK7 2006, 2.4 tdci, 140ps + TUNIT box = 165ps jumbo rwd known as "Big Blue" to the kids.
furnitureman
Postby angeleye » Sun Sep 02, 2012 3:06 pm
was fault codes deleted when pump was changed as them codes point to pump timing solonoid needs replacing
angeleye
Postby Jonesyscoob » Sun Sep 02, 2012 4:16 pm
Sorry van is 2.0 2002 fwd transit had no codes since pump change and van did 40 miles before this fault appeared?
Jonesyscoob
Postby Frag » Sun Sep 02, 2012 4:35 pm
Can also be due to basic pump timing being out,or slack in the chain between pump and crank sprocket,there was a TSB for this concern after pump replacement.......
If it runs ok but with a loud/harsh diesel knock,timing solenoid on bottom of pump probably failed as mentioned.
Frag
Ford Technician
Postby Jonesyscoob » Mon Sep 03, 2012 7:42 am
Timing looks ok but there is a little slack what's the best way to take it up? Doesn't seem to be a diesel knock, is the solenoid the small part on bottom of pump with 2 torx fixings, is it a simple removal and replace as have one on another pump in case?
Thanks for all your help so far
Jonesyscoob
Postby APH » Mon Sep 03, 2012 9:47 am
Timing solenoid is the other side of the pump to that plate, got two wires going to it. Yes its as simple as remove and re fit, cut wires then re join them, soldering prefferaly (DONT try and unplug it in the module on top, you will kill the modle) Also, dont get the timing solenoid mixed up with the metering one that sits between the injection pipes on the back of the back of the pump and also has two wires going to it :wink:
Andy. :D
(\__/)
(")_(")
this is bunny
APH
Postby Jonesyscoob » Wed Sep 05, 2012 7:05 pm
Have re checked timing and fitting another chain and tensioner from a good engine we had, still have a noises think? And codes are on and off intermittent can any one help from the video of engine running
http://www.youtube.com/watch?v=Q7OMGGcj ... ata_player
Jonesyscoob
Postby APH » Wed Sep 05, 2012 7:23 pm
sounds diesel knocky but not like the usual solenoid failure as it gets better with higher revs :? tickover sounds ok. I would still replace the solenoid, but just out of interest where did the pump come form,was it a recon one, as it should be a warranty job. If however it was a second hand unit, you may be stuck with the cost :(
(\__/)
(")_(")
this is bunny
APH
Postby Jonesyscoob » Wed Sep 05, 2012 10:19 pm
Pump was taken from a good engine we have, I have another solenoid I can try just didn't think it would be that? Reset timing gold links in line with points, turn by hand 2 turns and all pins locate correctly although chain does seem to click and jump up a little when turning by hand?
Jonesyscoob
Postby Jonesyscoob » Thu Sep 06, 2012 7:27 pm
Also do i need special socket to remove timing solenoid and what else could cause the diesel knock as codes are there all ay today!
Jonesyscoob
Postby inasinman » Mon Mar 12, 2018 5:30 am
hi there
I know this was an old post. I'm having the same proble. Could u tell me if you'd ever fixed the problem.
Cheers
MK6 125/350 LWB 2.4 RWD
inasinman
Postby andz327 » Mon Mar 12, 2018 3:53 pm
inasinman wrote:hi there
Cheers
Youve a better chance posting your problem mate , that way you'll get answers this duxe might not be on anymore
andz327
Postby knobby1 » Mon Mar 12, 2018 7:41 pm
Cheers
Aye...this thread goes back 6 years...highly unlikely the OP is still with us..
