Fwd Transit 280 di keeps cutting out
Re: Fwd Transit 280 di keeps cutting out
Postby Simtrike » Mon Feb 11, 2013 4:25 pm
Will pump and injectors from a 260 51 plate fit a 280 51plate and will it need reprogramming
Simtrike
Postby karl » Mon Feb 11, 2013 6:39 pm
Hi hope this helps
P1665 is intake manifold tuning valve to high bank 2
P1563 is system voltage high
P664 is the same as p1665 but description a bit different
P1335 is crankshaft position sensor
None of those codes doesn't even suggest fuel pump !!!
This reminds me of a passat with this proplem I took all the throtale body off and give it a good clean with brake cleaner,clean all sensor etc and ran perfect no more stalling wen it went back to idle
karl
Tranny Lover!!!
Postby angeleye » Mon Feb 11, 2013 9:11 pm
karl mcghee wrote:Hi hope this helps
this could very well be pump.or edc on pump if it isnt the wiring to it....dont take to much notice of the p1335 that could very well be just it stalling/cutting out
you would have a job taking off the throttle body on a mk6 diesel transit :lol:
where did you get your code definitions from as there wrong
p1665 injection pump module comunication
p1664 injection pump module requesting
p1563 injection pump module
no sign there of it being anything to do with the pump :?
angeleye
Postby karl » Mon Feb 11, 2013 9:54 pm
Here is some more
P1665; evap purge solenoid control circuit
P1563, set speed difference to high
P1335 ckp - circuit
Now these codes are from my support site from launchtech
Diagnostics
karl
Tranny Lover!!!
Postby karl » Mon Feb 11, 2013 9:55 pm
Were are your codes from
Were your codes from I also have a book with over 2700 codes in it with a description of each code !
karl
Tranny Lover!!!
Postby angeleye » Mon Feb 11, 2013 10:03 pm
you can only go with what you thought was right
try this link
http://www.dieseltalk.com/support/DTC.pdf
also do a search on this site you will find these codes will crop up quite alot
would be intresting to see what your scanner would of come up with
angeleye
Postby karl » Mon Feb 11, 2013 10:21 pm
Even thow codes come up it doesn't mean it is that fault,in many cases its something else wot makes codes appear
karl
Tranny Lover!!!
Postby angeleye » Mon Feb 11, 2013 11:12 pm
karl mcghee wrote:Even thow codes come up it doesn't mean it is that fault,in many cases its something else wot makes codes appear
yes thats why its suggested op looks at wireing first,
dont launchtech give you all the codes for different makes p codes on one make not same meaning as another.
p1563 pump related on ford /wiring related on vw but still related to pump :?: i dont no just asking
p1664 relating to heating on mb :?:
angeleye
Postby karl » Tue Feb 12, 2013 12:30 am
Yeah I get wot ya mean but launch is one off the leading diagnostic equipment suppliers so I go of their codes and I updated every month for a cost of x amount of pounds a year
Launch technology is better then snap on in my opinion
karl
Tranny Lover!!!
Postby Simtrike » Tue Feb 12, 2013 8:00 pm
Right can get a transit 260 injector pump with injectors and pipes will it fit my 280
Does any one know
And will it need reprogramming if so how much would it cost to reprogram
Or can I just put it on
Is there ny were ells on the loom to heck for damage to wire
Can't wait to get my van back on the road
Simtrike
Postby ake » Wed Feb 13, 2013 8:16 am
Simtrike wrote:Right can get a transit 260 injector pump with injectors and pipes will it fit my 280
Does any one know
Pump will need programming in. Injectors dont
karl mcghee wrote:Yeah I get wot ya mean but launch is one off the leading diagnostic equipment suppliers so I go of their codes and I updated every month for a cost of x amount of pounds a year
That may be so but you are not posting the Ford descriptions, so they are not any help! If anything you are causing confusion.
2 x 18 Custom 270 Trend
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
Or is it something worse?
Postby Simtrike » Wed Feb 13, 2013 9:47 am
Right now I k ow it will need programming does any one know the rough cost of getting this done thanks
Simtrike
