Have replaced EPIC pump with Bosch manual - set up as per Dieselhead123 instructions (0.68mm advance at TDC)
Removed max fuel tamper ring and added 1/4 turn clockwise to increase max fuel
Screwed mid-range in 2 turns on pump top
I will also be fitting an intercooler, so no doubt these settings are just the start.
There is quite a lot in various posts about setting the fuelling up on these pumps - quite a lot of conflicting info too
What is the tried and tested procedure to get this right? This is a camper, so smoke has to be kept to a minimum to avoid upsetting happy campers and getting banned from campsites ...
