Dodgy Key Fob Mk7
Dodgy Key Fob Mk7
Postby ChopperHuggett71 » Tue May 14, 2013 9:26 am
HI can anyone help, I have an intermittent problem with key fob. It doesn't seem to be holding charge when van is sitting overnight. But when I run it for half hour or so its fine.
I have been advised that an 09 van fob shouldn't have run down so quick and that I should be looking at the aux battery under seat.
So I trickle charged the front one and still nothing. Is there something Im missing or is it a case of just biting the bullet and getting a costly replacement fob from main dealer.
Thankyou
ChopperHuggett71
Re: Dodgy Key Fob Mk7
Postby fedup2 » Tue May 14, 2013 3:41 pm
Charging the battery isnt going to do anything any different to running it on the van,if its knackered its knackered no matter how you charge it.
Id be testing the batteries properly before buying a fob.
Launch x431 owner ;)
fedup2
Postby ake » Tue May 14, 2013 7:50 pm
Have you actually had the van battery's properly tested?
Postby ChopperHuggett71 » Wed May 15, 2013 10:31 pm
No I will get my neighbour to take a look at them he has all the fancy doofers to be able to check.
I will let you know what the outcome.
ChopperHuggett71
