Codes to identify which Clutch I have?
Postby The gadge » Fri May 17, 2013 5:35 pm
I have a 2003 2.0 td and my clutch needs replacing. Does anyone know how I can find out weather it has a duel mass flywheel or a solid flywheel before I take it to bits. As if its a fuel mass flywheel I know I would need to change that with the clutch and if its a solid flywheel I would just require a clutch.
I'm hoping someone will know by chassis code etc.
The gadge
Re: Codes to identify which Clutch I have?
Postby Wadey » Fri May 17, 2013 7:59 pm
It's something to do with the power it has I think but that's not saying someone has already replaced a DMF with a single mass one ?? Without taking it out you won't know it don't really make that much difference the clutches are the same so just order both and take the flywheel back if yours Is already converted
just follow the onscreen instructions and it's fairly idiot proof...trouble is, we keep producing better idiots
Wadey
Postby The gadge » Mon May 20, 2013 7:40 pm
Thanks.
I got my clutch today after contacting a ford dealer I was informed that mine should have a solid flywheel, gonna get it fitted this week so fingers crossed they are right :)
The gadge
