Mk4/5 Rear twin wheel hubs to Mk1/3 axle?
Postby RP123 » Mon May 20, 2013 2:52 pm
Hi guys,
Does anyone know before I go messing around stripping axles to see if they fit, if mk4/5 rear twin wheel hubs will fit the mk1/3 twin wheel rear axle casing?
I've fitted mk5 ifs front suspension to my mk1 and I'm going to stick with the 15 inch wheels and want to know if I can swap the hubs over on the mk1/3 rear axle I will be fitting so that I can fit 15 inch wheels to the rear too.
Cheers
1999 Tourneo GLX85PS
1973 Mk1 Transit Canterbury savannah
1963 Mk3 Zodiac
1964 Anglia 105e
RP123
Re: Mk4/5 Rear twin wheel hubs to Mk1/3 axle?
Postby MinorMatt » Mon May 20, 2013 2:57 pm
I *think* the wheelbearings are a different size. Whats wrong with fitting the whole mk4/5 axle?
Postby RP123 » Mon May 20, 2013 3:39 pm
Thanks Mat,
The mk5 axle is wider, spring saddles need modding etc don't they to fit the mk1? Plus the mk3 axle I have to go on has a nice low mileage 4.63 diff in it, the van its on has done 10,000 miles from new.
1963 Mk3 Zodiac
1964 Anglia 105e
RP123
Postby MinorMatt » Mon May 20, 2013 4:06 pm
I guess your going to be taking things apart to look anyway then?
Postby Luke » Mon May 20, 2013 6:41 pm
not sure but have a search for ken b's posts on here he may have some info - he fitted a mk6(yes mk6) diff into a mk1 axle casing :D
Postby RP123 » Mon May 20, 2013 10:07 pm
Cheers for your input guys. :)
Looks like I'll be taking things apart to see what fits what. :lol:
I was aware Ken B used a mk6 diff in mk1 axle casing, he told me in a email. :wink: I want to use the mk3 axle I have for my mk1 without disturbing the diff but would like to use 15 inch wheels all round as I have fitted mk5 front IFS suspension which already excepts 15 inch wheels, if its gonna end up being alot of faffing around I'll have to have a re-think on the wheel situation. :)
1963 Mk3 Zodiac
1964 Anglia 105e
RP123
Postby MinorMatt » Tue May 21, 2013 7:36 am
Get some 15s redrilled to 6 x 170? (assuming the center bore is the same)
