HPU Replacement
HPU Replacement
Postby JCman » Tue May 21, 2013 3:10 am
Hi There folks...
I've got a 2003 transit with the ASM unit and the HPU is not working (need to hit with a hammer so it can work) and I would like to know if anyone or if you know someone around Penrith in NSW that can replace this unit??
Thanks in advance.
JC
JCman
Re: HPU Replacement
Postby MinorMatt » Tue May 21, 2013 8:32 am
I don't know the ASM system... but from reading elsewhere on this forum, I believe the HPU is a VERY expensive part and is meant to be replaced as a complete unit. However, its often the pump that fails and a VW ABS pump can be modified to fit
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
