tibbyclarke wrote:thanks but managed to round all bolt heads !!! any suggestions ????
karl mcghee wrote:tibbyclarke wrote:thanks but managed to round all bolt heads !!! any suggestions ????
did you use a spline socket ?
the correct one would off done it the hexagon socket same as the bolt head
my oppninon i would be useing heat to warm them if i rounded bolt heads off not to much but enough to crank the with a pair off mole grips
Guy88 wrote:karl mcghee wrote:tibbyclarke wrote:thanks but managed to round all bolt heads !!! any suggestions ????
mole grips??
there inset into the pully and would just slip
I would go for a good quality 6 sided impact socket and get someone to hold the socket while you push down on the bar
75psT330lwb wrote:how do u know there is no head on them? is it your van? i too would try a good six sided socket as the metal which is left may be enough for it to grab.
taz666 wrote:angeleye wrote:karl mcghee wrote:15mm socket hex you want an air gun or lock the fly wheel with the flywheel locking pin
this is a very bad idea, if the crankshaft sensor bracket breaks it may require the gearbox off to replace it,
get someone to help put it in gear foot on brake pedal..long breaker bar and a good fitting socket,
if you want to lock flywheel take starter motor off and lock it there
x2, do not use the flywheel locking pin, it WILL break the sensor bracket, been there done that, as angeleye says 4th gear handbrake on tight and a decent 15mm socket and breaker bar
Guy88 wrote:i managed to fit the sensor bracket on my mk7 without removing box, was a b*stard thou
