Transit van turns over but wont start (year 2006)
Postby SS11NGH » Mon Aug 12, 2013 2:53 pm
Hi my 2006 transit diesel turbo 2.5l will turn over on key but wont start. I have change the injector pump, EG valve. The van just randomly stopped on the motor way and was towed away. I have taken it tothe mechanic but he doesnt seem to know the problem, a machiene was put on to find problem and a relay fault was found, we then put a new injector pump which comes with the relay but it still wont start. Total cost to me so far is £1000 sooo a solution is needed as i cant keep paying more for it.
All lights on dash comes on as normal soo its a real pluzzel.
Can any1 help me with a solution please!! Thanks
SS11NGH
Re: Transit van turns over but wont start (year 2006)
Postby ake » Mon Aug 12, 2013 6:39 pm
No such thing as a 2.5 in 2006, so what is it?
2011 Ford Mondeo 2.0 Titanium X
4 x Customs
2 x 350 MK7
7 x 260 MK7
Or is it something worse?
Postby SS11NGH » Mon Aug 12, 2013 9:25 pm
Sorry mate its a 2003, i got confused with my car
SS11NGH
Postby Altransit » Mon Aug 12, 2013 9:27 pm
SS11NGH wrote:Sorry mate its a 2003, i got confused with my car
Yes, but what engine does it have :?:
Postby SS11NGH » Tue Aug 13, 2013 12:15 am
2.5 turbo diesel
SS11NGH
Postby Altransit » Tue Aug 13, 2013 12:51 am
SS11NGH wrote:2.5 turbo diesel
No it's not :!:
It's either a 2.0 front wheel drive turbo diesel, or a 2.4 rear wheel drive turbo diesel :wink:
Postby karl » Tue Aug 13, 2013 8:53 am
when you put the pump on did you get it coded to the van
sounds like the imoberliser
what the pats like doing on the dash where clock is
karl
Tranny Lover!!!
Postby SS11NGH » Tue Aug 13, 2013 1:46 pm
Its a 2006 t260 turbo diesel 2.0l. Im sorry for confusion but this is the model
SS11NGH
Postby SS11NGH » Tue Aug 13, 2013 1:48 pm
karl mcghee wrote:when you put the pump on did you get it coded to the van
The pump was not coded to the van , it was a direct replacement
All lights on dash light up as the normal ones shud wen on ignition
SS11NGH
Postby MinorMatt » Tue Aug 13, 2013 2:18 pm
Injection pumps are part of the immobiliser system (except on TDCi models) and need to be programmed/coded to match the ecu/keys.
96 N 120 Turbo'd DI SWB Low
97 P 150 76PS Di SWB low ex essex police
Lucas laser 2000 & IDS onwner
Postby SS11NGH » Tue Aug 13, 2013 5:21 pm
Soo how would i have to get that done and where do i get this code from?
SS11NGH
Postby Altransit » Tue Aug 13, 2013 10:44 pm
The pump will need to be coded using the Ford ids software, usually only a Ford dealer has this software :wink:
Was the pump changed because it wouldn't start, or has it only been not starting since the pump was changed :?: FWD TDDi engines suffer from the pump wiring chafeing, where it crosses the starter motor :)
Postby SS11NGH » Wed Aug 14, 2013 1:40 am
Altransit wrote:The pump will need to be coded using the Ford ids software, usually only a Ford dealer has this software :wink:
The pump was changed because it would start and also because a computor was put on it and sed a relay was at fault so we changed the pump that has the relay on it.
Do you know how much this cost to get it coded and if there could be any other faults?
SS11NGH
Postby SS11NGH » Wed Aug 14, 2013 10:22 am
Diesel still gets to the injector but it wont start.
SS11NGH
Postby ake » Wed Aug 14, 2013 8:10 pm
SS11NGH wrote:Diesel still gets to the injector but it wont start.
How good is the diesel spray at the injectors? Hitting the scuttle? Or just dribbling out?
4 x Customs
2 x 350 MK7
7 x 260 MK7
