If your really stuck?
Check out this bodge
viewtopic.php?f=18&t=165640&hilit=Temporary+selector
knobby1 wrote:
I'd be replacing the turret bearing assy when you get a chance...or it will eventually fail again.
Punto443 wrote:If your really stuck?
t2myd wrote:I ve had this problem , I squirted mine with wd40 got it going again then used spray grease the next day never had any problems since
Johnl358 wrote:t2myd wrote:I ve had this problem , I squirted mine with wd40 got it going again then used spray grease the next day never had any problems since
Hi
How did you put grease or wd in there
