vanduara37 wrote:not yet, but what I have noticed is all the calibration files are in "rar" in the folder do I need to unzip them all ?
yes
vanduara37 wrote:Here,s exactly what I done with the 2 discs I got.
Disc1
Install ids, reboot computer.
install patch, reboot computer.
Disc 2
Install calibration file.
Got the Ford extended file sent to me, opened it (there was no install instructions just opened a box stating module programme enabled to 20/5/2014 do I want to extend this by 120 days. I chose NO. Have I gone wrong somewhere ? I am using windows7 but have also tried running on windows XP3 in compatibility mode.
I have been able to use VCM, done pump/pilot learn after fitting new PRV.
vanduara37 wrote:Still no joy.
The Ford extended application, what exactly is this when I open it I just get message saying module programming enabled till 20/5/2104 do I want to extend this by 120 days, is this correct or have I missed something.I have put it in the Ford motor company file ?
alz4321 wrote:loot34 wrote:1 disk will be full ids v81 + c81 installation on dvd, the other disk will be ids v86 and patch only on a cd.
Install v86 + patch from cd then install v81 calibrations (installer) from dvd.
After this you need another patch called Ford extending program which you simply run and it extends the module programming function.
My second disc with the calibrations on is damaged ..... it has a dark patch on the disc
alzee20 wrote:alz4321 wrote:loot34 wrote:1 disk will be full ids v81 + c81 installation on dvd, the other disk will be ids v86 and patch only on a cd.
I have just made the purchase and am attempting an install on windows 8.1. No joy so far, I can't install the 2nd disc as my main PC won't read it and the Lappy has no disc drive :/
Could anyone help me out with the software?
Clotaire wrote:I see them on buyobdii.com all the time for around 100 to 110. Have considered purchasing this and was wondering is anyone has on here. I know it's bootleg and my one and only worry is virus in the software. Anyone got thoughts?
