Any suggestions how to fix or where to buy from? Is it just dust cover or something?
Axle is from 190 1986 Transit..
Cheers!
SuolaMk1 wrote:cheers mate!
in the outer end of this "cover", you can see some sort seal, axle bearing seal?
part nro 3..
Restorationvanman wrote:SuolaMk1 wrote:cheers mate!
having looked again at the pictures and exploded drawing I think the job of this sleeve is to prevent any grease that passes the seal from contaminating the brake linings
SuolaMk1 wrote:Ended up cutting 83mm pipe and glued it with gasget silicone
