by rikki19 » Sun Apr 13, 2014 2:45 am
Hi guys , Just wondering ...... is it an easy job to lower the steering column ? I need to pull out the instrument panel to access heater blower and resistor and the wheel is right in the way. Also , by reaching in thru the radio hole , I've tried to loosen the blower motor but can only turn it 1/4 " or so . Someone mentioned a plastic tab that needs bending back . Is that the one on top of the motor or is it further back near the resistor ? There's a plastic tab at 12 o'clock that feels like it will snap off if I pull any harder .
Mk 6 2.3L petrol 2001 MWB T330 275K
Mitsubishi WA Express 2.4L
Proton Satria GTI 2003
