jay wrote:I have run a mk6 75ps on 50 mix veg oil(new veg oil not used) and it ran ok but keep a spare filter in the van along with a bit of diesel to fill up new filter if it gets clogged up...veg oil as u know will clean the fuel pipes and tank of sludge build up and will clogg the filter quickly when you first use veg oil but over time its ok..I thought i had killed a pump on that van as it suddenly stopped on me one day but it was just a clogged filter and once a new one fitted it ran fine and never had the problem again... running my current 100ps one on 50 mix again but in winter i run a 25% mix of veg oil.. I have noticed on this 100ps one it now idles smoother and i get same mpg...
