ake wrote:Normally the two wires from the pump are the up and down wires, they go one to each side of a 2 way switch, then you connect a fused 12 volt supply to the middle pin of the switch.
APH wrote:surely the two isolator wires are just that, to isolate the lift so it won't work, by having a switch in the cab. Do they just not connect together through a single pole switch, eg join the two wires together - lift works, seperate the two wires - lift dosent work. As the op says they aren't for the up / down buttons as the buttons / handhled are ALREADY fitted and conneted to the pump unit.
