by dieselhead123 » Wed Aug 06, 2014 11:32 pm
Hi there, have you still got the 'black smoke' problem?
It is a simple task to check the condition of the chargecooler core, if this were leaking into the intake then it would cause poor starting issues, particularly with a re-start soon after turning off. A seawater leak into the inlet manifold would also cause seawater to be drawn into the LDA, (manifold pressure compensator), on the top of the injection pump when the engine was 'throttled back' during the shutdown phase. Seawater in the LDA will cause corrosion of the internal parts resulting in the inability of the pump to match fueling to boost levels. At full throttle the preasure in the intake side would be greater than in the seawater side of the cooler so any leak would be 'held back' until shutdown. What sort of boost levels are you achieving?
A simple test would be to run the engine at idle from cold with the flexible pipe between the chargecooler and inlet manifold removed, if the chargecooler core is faulty you will see water emerging from the open end of the chargecooler. Testing like this for a period of about ten minutes would be all that was required to establish if the cooler core were faulty.
I can supply a new set of genuine Stanadyne injectors if needed, but at this stage I would say that this was unlikely.
Let me know the outcome of the 'test' and I will happily advise further.
