my transit mk4 rear wheel brake cylinder want help
Postby Thaivan » Thu Jul 17, 2014 3:08 am
This is my transit.
I want know that my transit use rear wheel brake cylinder 20mm bore or 20.20mm bore?
(if my english lang is bad ,i am sory because my country no use english lang)
thank you. :D
Thaivan
Re: my transit mk4 rear wheel brake cylinder want help
Postby motorman116 » Thu Jul 17, 2014 6:37 am
Why don't you just measure the internal bore size of the wheel cylinder, or just replace both of them :?:
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby Thaivan » Thu Jul 17, 2014 7:28 am
in ebay has type 2.0mm and 2.2mm bore.
i want buy it but i don't sure
in Thailand no have transit part.
thank you.
Thaivan
Postby Thaivan » Thu Jul 17, 2014 7:44 am
tell me please.
Thaivan
Postby MinorMatt » Thu Jul 17, 2014 7:45 am
If you replace both it doesn't matter.
Also, with the cylinder off like that you can measure the diameter of the bore.
Those are your choices - we can't tell you what was fitted.
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby bambi mk 1 » Thu Jul 17, 2014 8:41 am
Your Transit should have 25 mm cylinders as it has 15 inch wheels.
bambi mk 1
Postby Thaivan » Thu Jul 17, 2014 11:53 am
You can sent ebay link of it. for example
please
i can buy form ebay because my country not sale
please,..
thank you
Thaivan
Postby Mr RVM » Thu Jul 17, 2014 1:17 pm
These are the one's you should havehttp://www.ebay.co.uk/itm/Ford-Transit- ... 27be41f316 25.4mm
Mr RVM
Postby Thaivan » Thu Jul 17, 2014 2:55 pm
thank for help. :wink:
Thaivan
Postby Thaivan » Sat Aug 16, 2014 1:24 am
brake cylinder sent to thailand. :)
thank you.
Thaivan
