PistonMeetValves wrote:Scratch the above post! I've decided to try and do the cable-tie-thebugger-open mod.
ANOTHER QUESTION (who'd have thought??) !
- I've read its best to screw pump up at same time? I'd rather have the MPG's, so can I just do EGR mod thingie and it'll run better? also considering putting small measures of 2T oil in after reading some good reviews on here with it....!
Thanks guys, the knowledge you chaps have is bloody priceless!
darkbluevanman wrote:I get the impression water run down the door seal rubber and into the step well.... mine had and rotted the lip that holds the seal on, then into the sill (which almost survived because it was waxoyled 6yrs ago) chopped out and replace and MADE SURE!!!!!! The drain holes in the step well were clear
PistonMeetValves wrote:darkbluevanman wrote:I get the impression water run down the door seal rubber and into the step well.... mine had and rotted the lip that holds the seal on, then into the sill (which almost survived because it was waxoyled 6yrs ago) chopped out and replace and MADE SURE!!!!!! The drain holes in the step well were clear
Drain holes you say? Hrrm, might have to try and see if mine has them
PistonMeetValves wrote:Right, done the EGR mod, and screwed the pump up x1.25. What a difference! Combined with my light amount of 2T and the two mods together, it is quiet (induction ROOAR isn't lol), noticeably more powerful and doesn't seem to be using more fuel.
Thanks for your reply, RVM! (And to everyone that has helped, it really made a difference guys ) - Helped ease my mental suffering lol. I was approached by a friends father today, who upon finding out that I had tied the EGR said that I should put it back to standard, as it could fry the engine? Is there a real danger of this happening? Kind of worried now! I've ordered the EGR blanking plate as a cautionary measure, as it would stop hot exhaust getting to my (should be..) cold intake. If I blank the EGR (and I have hunted for an answer), do I have to do anything to the vacuum hoses after the blank is installed and the flap is tied up? Wouldn't have thought so but just want to be sure.
Is it best to blank EGR end, or exh. manifold end? was probably going to do EGR end?
Also, the engine seems quite hot when its up to temperature, but I've put it down to it being a dirty great 2.5Di lol, moving that weight about most engines would get hot
Cheers again guys!
Restorationvanman wrote:Poppycock I say POPPYCOCK some on here have removed flap altogether and have no issues
Blank EGR at the exhaust end if you can (but either end is fine)
Restorationvanman wrote:Try pulling the cable out from under the slam panel and try the pedal with the cable free of any tight bends and make sure that the metal bracket that the square end of the cable adjuster is not twisted so that the inner cable isn't rubbing hard against the side of the threaded tube of the adjuster, that sometimes makes a difference (just twist it with a pair of grips till you can see the cable is not rubbing as it enters)
Restorationvanman wrote:Edited above post...Re operating rod
MinorMatt wrote:Its the opposite... you have stopped the exhaust gasses entering the engine.
When the flap is closed there is a pressure differential on the 2 sides, causing a vacuum on the downstream side. This vacuum is used to "lift" the valve from its closed position to allow exhaust gas to enter the engine to be re-burnt.
By tieing the flap open, there is no vacuum, and the EGR valve can't open, preventing the gas from entering the engine!
Does that make any sense?
