hi my air cons not kicking in im not getting a live to the pump, fuses and relays look fine push the button green light shows up fan runs but pump doesn't click in... no + or - to pump any ideas???? also does the ac come up on ids because I cant see nothing...
how can i check the pressure switches I've seen one its got 4 wires under fuse box sits on wheel arch? wheres the other one? is air con on ids or not? cheers
