Hi there I've been having Clutch problems for a little while on my MK6 2.3 petrol, I managed to get a complete Clutch and Dual mass Flywheel from Birchwood Ford in Eastbourne for £190 !!!
Just had them fitted and I am still getting a faint crunch from the gearbox when I change gear , I am guessing that the clutch slave cylinder needs bleeding/replacing, can I bleed the slave cylinder while gearbox is in van ?
If not is it easier to change the slave cylinder complete ?
