by Janek » Sun Sep 21, 2014 8:19 am
I bought my 1997 ford transit motorhome, which is automatic, and done around 41,000 miles, 2 months ago, all was fine until I went up a steep hill, put the accelerator to the floor, the gears changed down to low gear but then stayed there all the way up the hill, and then on the level the van did not seem to want to change up into third gear, the revs where going really high so I pulled into a car park and called the AA as I did not want to do any damage. It was dark and the aa man looked under the van while I changed the gears and he said there was a slight dripping of oil when I changed gears. Anyway, somehow I had a puncture while in the carpark, the guy changed the tyre but the spare wheel was not fit to drive on so was taken home on the back of the pickup.
I took the van to the local gearbox centre who said they could not get accurate readings as the van is old, said the gearbox seems fine, the oil is clean, and that the problem could either be from the electronic modulator or the electric sensor, both of which they cannot get hold of as no parts anymore. They cleaned the modulator which made no difference so I went to collect the van as they could do no more.
Now I do have a six month mechanical breakdown warranty but I suppose they will say it is an electrical fault
I did buy the van through a garage who was selling it for his friend but paid the friend directly although my receipt is from the garage, and he said he will try to help.
Anyone any ideas please?
The van will drive in first and second but not want to change up into third although it will do with very high revs. or if I change it manually, so poor van is no use.
Jane feeling really upset.
