Hi guys,
Wondering if anyone has had error codes when trying to do module programme in FORD IDS
"When i try to perform module programming i get error "0x0" or connection can not be established please check wires."
Error code:
9-0x0 851082
9- 0x0
I have tried IDS on another mark 6 (2003, mine is a LATE 2005) transit and get same results.
I have tried on mk7 transit and seems to work fine
I contacted the supplier and they said to try
"please start the moudle match, then do programming"
like can be seen in the picture below.
[url][URL=http://s36.photobucket.com/user/sandy_lewis2/media/IDSError_zps51b258be.jpg.html]
[/url][/url]
What is module match?? i was abit confused by this as the icon the supplier has highlighted is the network test icon. When i try to do network test it says network test failed.
i also read somewhere on the internet that sometimes this error can ocure when following the ignition off prompt from IDS. It was suggested just to leave the ignition on for module programing and ignore such prompts by just pressing the tick icon.
Unfortuneately i am away atm so cannot try any suggestions for another week or so, but thanks in advance for any of your help and once solved i'll be sure to follow up on this thread
cheers
