blue estate wrote:Have you actually had the fault codes read ?
It is impossible. If the engine goes into limp mode - you must get errors, probably P0251 or/and P1211. Use good tester.dg solutions wrote:blue estate wrote:Have you actually had the fault codes read ?
Yes, I have got a fault code tool. No codes are stored.
Usually it is only first step...ake wrote:Get a leak back test done, and prepare yourself to buy a set of injectors
MinorMatt wrote:A generic obd tester won't read your van... what scanner do you have?
wojciech wrote:It is impossible. If the engine goes into limp mode - you must get errors, probably P0251 or/and P1211. Use good tester.dg solutions wrote:blue estate wrote:Have you actually had the fault codes read ?
Yes, I have got a fault code tool. No codes are stored.Usually it is only first step...ake wrote:Get a leak back test done, and prepare yourself to buy a set of injectors
Because if injection pomp is worn-out, injectors renovation can help only for short time. In Delphi tdci, if injection pump is ok and in good condition, injectors can leak back very, very much - without limp mode.
I think you have worn-out both: injectors and pomp...
Try do first injectors - not only valves, also sprayers it is good to change (only original Delphi parts). Check for metal filings in fuel in injectors.
If they are - pomp is broken, don't try start engine again. In this case, whole fuel system is for rinsing, pomp for regeneration in Delphi workshop.
dg solutions wrote:When I turn off and re start it must re set
