Hi guys post about leak though it was leaking from fuel pump on engine block but seems to be from fuel pump but it's not diesel defo oil any help would be great
Found leak was leaking form vacum pump bolt tiny drip at bolt on vacum pump and dripping down had vacum gasket changed but still leaking from mounting bolt on vacum pump but still leaking oil from one of the mounting bolts so think it must need a new pump is this a comon problem on fwd vans ?
