I have a not starting problem on My Mk6 2ltr Di Transit. I have read lots of similar posts on here and tried several of the suggestions. The background to the problem is. About 4 months after buying this Transit (its a 2001 model by the way)I had a fire in the engine bay. It turns out that there had been a diesel leak from the pump and had soaked the starter and lots of other stuff in diesel. the result was I had the pump replaced and the starter motor, and also the main cable loom to the pump etc so all that is newish. about a year after this was done I noticed a loss of power on hills and under load. however it was starting fine it ran otherwise quite well until one day the problem got worse. I was coming off the motor way up the off ramp had to stop at the lights and the engine died and would not restart.
The RAC were called and started the engine with easy start but the motor just ran for a couple of seconds and stalled. After doing this several time and trying several things the guy was at a loss as to what was wrong. Diesel was getting to the injectors and with his battery as donor the engine turned over well enough but would not maintain going once started. He then Towed me home.
I have since changed the following. Battery, Air filter, fuel filter. I have ordered a crank sensor as I measured the one fitted and it read 760ohms and i am sure I have read somewhere that it should be 400Ohms. Since doing all this it does not start on easy start now. I am also looking at changing the Injectors but it seems odd that they would all fail together. Any helpful suggestions would be much appreciated.
