MK6 Cannot connect to IDS
Postby sand010 » Sun Oct 19, 2014 8:19 pm
Well i came home after my 5 week trip ready to try and get PCM programming working, would you believe it i cannot even connect to IDS at all now :twisted: :twisted: :twisted:
I have also tried with another scan tool same result cannot communiate at all.
I have checked the DLC with a multimeter
Only thing that was a bit strange was that PIN read 0.025v is this correct? I am still getting 12+v on PIN 16
Anyone got any suggestions?
taa
sand010
Re: MK6 Cannot connect to IDS
Postby karl » Sun Oct 19, 2014 8:23 pm
fuse blowen :?:
karl
Tranny Lover!!!
Postby ake » Sun Oct 19, 2014 8:24 pm
Yeah, I would be checking all the fuses
Postby sand010 » Sun Oct 19, 2014 8:52 pm
I have checked fuse 21O the one under the passenger dashboard, far right, in the middle, its labled as tacho/clock but apparently deals with the DLC. Rekon it could be another one?
sand010
Postby ake » Mon Oct 20, 2014 8:25 am
sand010 wrote:I have checked fuse 21O the one under the passenger dashboard, far right, in the middle, its labled as tacho/clock but apparently deals with the DLC. Rekon it could be another one?
Check ALL fuses.
Postby sand010 » Mon Oct 20, 2014 9:50 am
Thanks ake just updated my ids and autocom. Problem solved :D . Next how to get module programming to work without giving mme error codes
sand010
