Hi there,
There is no Bosch part number for the marine Di pump, this is because Bosch did not develop it.
I have seen a number of different pumps used on marinised Di's, including Bosch part number 0460 414 154.
The 154 pump was originally developed by Bosch for use on the 80ps turbo Di engine, the ford part number for this pump starts with 97VB, suggesting the pump was first used on a Transit from 1997. These were only sold outside the EU.
I do doubt that a pump developed by Bosch for an 80ps commercial vehicle would have been used on a 130+ marine engine without some sort of 'alteration' from standard, the marine engine suppliers might be prepared to share information with you.
By far the best solution would be to do as Bosch would have done and develop a pump to suit your application as we are in the process of doing. See links to our work;
viewtopic.php?f=5&t=137262and here;
viewtopic.php?f=27&t=92701TIM
