angeleye wrote:Im not douting your wisdom or knowledge karl....im looking at psi..as thought thats what op meant as 220 bar is way way to high.sure these should be at around 400/450 psi.irc mk6 2.4 tddi checked cold with fuel discomnected should be 19 bar about 300 psi with a 60 psi 4 bar allowance....and think tdci is higher.l do stand to be corrected.
eddydar wrote:Thanks for the replies guys, yes cam sensor has been fitted wont start without.
The compression test was done and engine was not running. and I got an average of 220 bar about 350 psi
The battery light concerns me as I've recently changed the starter motor, and its been on ever since wondering if I ve left a wire of as I understand that the starter and alternator are connected. Could this be causing my issues shorted out somewere ?? Will check this weekend when the light is better.
Yes used proper pins (extended pip pin for flywheel for tdci) allen key on crank at 11 o'clock, cams pinned at 6 pm.
Bloody annoying thing is that I modified a mondeo cam carrier (a lot of work i wont bore nayone with the details) and had it up and running using it for a few days then a cam nipped and cracked the carrier back to square one. You live and learn...
Just out of interest what are the torque settings for the head on a tdci are they the same as a tddi ?
bambi mk 1 wrote:220 bar = 3190 psi approx.You would need some starter and battery to churn that over.There is a difference in the injector heights between tddi and tdci cyl heads .Measure down through the injector holes with a calipers.
