loot34 wrote:57 way connector is the big ass white connector nearest the bcm, it Its where you add extra stereo wires for 4 speakers to the radio.
Your alarm probably wants the door ajar switches to sense an intrusion.
These are closed when triggered (earthed to bcm)
Front left
C3 pin 7
GN/VT
Front right
C3 pin 1
WH
Liftgate/rear door
C3 pin 13
YE/OG
Sld left
C3 pin 19
GN
loot34 wrote:C connectors are at the bcm, drop the front fusebox down and you'll see each connector.
If you post a pic of your instructions relating to this we can see if they should be joined at the 57 or bcm:-)
loot34 wrote:
Front left
C3 pin 7
GN/VT
Front right
C3 pin 1
WH
Liftgate/rear door
C3 pin 13
YE/OG
Sld left
C3 pin 19
GN
Users browsing this forum: Chug
