loot34 wrote:I'd plug them in if you have issues then add a resistor or keep the bulb in the circuit but hide away.
Keep an eye on polarity
There are some resistor boxes you can buy.
Not sure why the relay would be affected in mk7 setup tho.
loot34 wrote:I know, the same applies tho
Also it's nearly xmas so get onto it we want to see your van looking like Santa's sled
Matt716 wrote:I have these LED stop/tail/turn high level repeaters on my mk6 2.4 RWD. These are spliced into the rear light assemblies.
[img]<span%20class="skimlinks-unlinked">http://tapatalk.imageshack.com/v2/14/12/21/39e70e054e01bef683037482f2ac8f34.jpg</span>[/img]
Used to be Britax halogen lamps, but they used to burn out the hazard switch after prolonged periods of use.
motorman116 wrote:I take it that its these....
http://www.ebay.co.uk/itm/111257083489? ... EBIDX%3AIT
I have just ordered a set
