Alarm went off this morning on the van then stopped ,hubby went out just to start it and let it tick over for 15 mins (doing a camper conversion so it's sorn off) turned ignition &engine off but all ignition lights still on and buzzing , any ideas, also just noticed front lens is full of water , Tia
Water in the electrics is a defo no no!! Get it out or at least I plug the light from the rear see if that cancels out the problem. Other than that could be faulty ignition barrel ? Or bad earth to engine. That's been known to make engines rattle on after the keys been turned off??..
so because I have a bassbox in my van I should drive a saxo?!?! Wtf..?!?.. err..no!!
Thank you,for the info ,he tried turning it on and off quick 3or 4 times,and the lights stopped off, but when he done normal the light and buzzing stopped on so looks like you could be tight, thank you again
