Hi all I am chasing the Dragon with my mk 7 ( well trying to get rid of the P codes) and wonder if any one can tell me the normal readings the OBD2 will show for the MAP and MAF sensors in live readout.
As readings were P0100 I replaced the MAF to try to cure it but before I change the MAS I was wondering what the correct reading at idle and say 1500 rpm should be so I can see if im in spec befor getting another sensor if its not that causing the problem.
no duff wires found in the usual areas so the fight goes on
