Hi I am needing to change my engine on my 2008 2.4 tdci 115ps tipper. What is needed to do this ? . Do I need a engine with the same engine code as the one I have taken out , and do I need to use my old fuel pump and injectors etc any help would be great .
The injectors need to be coded in, fuel pump does not, it's just a pump. You ideally want the same model number of engine, and then once fitted you need to code the injectors, then carry out an injector learn, pump learn etc using Ford ids system
Ford Transit Custom 280S Trend 105ps Does this train stop on Merseyside?
