Hi all,
I bought a Mk6 2ltr TDCI 125 280 SWB Registered June 2006 last week. None of the interior lights nor the electric mirrors are functioning. I've checked the fuses and relays on the multimeter and all seems OK.
the PO mentioned something about having LED lights fitted but the work was never done, although he mentioned something about a module I assumed he perhaps meant a relay. Could any of the gurus shed some advice on what the cause might be. I found the fuse and relays schematics very helpful as the Haynes manual seems to only provide half of the required info.
Any help or hints greatly appreciated.
Archie
SWB 2.0TDCi (125ps) 280 Low Roof FWD 2933 mm 1974 mm 1974 mm 1188 kg
Transit 2000-06, 2.0L Duratorq TDCI (125PS),
Colour - College Blue 92
VIN Number: WF0VXXBDFV5C66145
Registration Number: V5 Ref No 21788205824
First Registration Date: 14.06.2006
Registration Country: GB
Primary Features
Build Date: 10.09.2005
Vehicle Line: Transit 2000-2006
Cab Style: Regular Cargo Van LCF
Series: 280S Series
Engine: 2.0L Duratorq TDCI (125PS)
Transmission: 5-Speed Manual Transaxle - VXT75
Drive: RHD FWD Axle Ratio: 4.23
Emission: Light Duty Truck Stage III
Air Conditioning: Manual Air Conditioning
Territory: (+)"GB"
Paint: College Blue 92
Interior Colour: Dark Graphite
Interior Fabric: Stylize (-G-C)
Minor Features
With Low Roof
With Rear Mudflaps
With Front Mudflaps
With Full Partition - Steel
LH Sliding Side Cargo Door - Low
With Hinged Rear Loading Doors
Southampton Plant Built
Special Order Paint
With SVO Application/Label
With Power Front Windows
With All Light Tinted Glass
Less 2nd Row LH Side Window
With Rear Blanking Panel
With Heated Windscreen
Less Heated Rear Window
Less Header Mounted Package Tray
With Partial Headlining - Moulded
With Roof Height Feature Pack 1
With Door Map Pocket
With Front Roof Grab Handle
With Load Space Tie Down Loop
Drivers Door Trim - Level 2
Passenger Door Trim - Level 1
Less Rear View Mirror
Drivers Short Arm Power Mirrors
Passenger Short Arm Power Mirror
With Drivers Seat Fixed Armrest
Less Passenger Seat Armrests
Less Passenger Seat Valance
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less 2nd Row Rear Seat
With Driver 6 Way Mnl Seat Adjuster
Less Adjustable Passenger Seat
With Door Dead Locks
Remote Control Door Entry - 2 Fob
Less Rear Window Wiper/Washer
With Driver Air Bag
With Spare Tyre Security Package
With Single Rear Wheels
5 1/2J x 15 Steel Wheel
195/70R 15C LI 100/98 BSW
Any Brand Tyre Vendor
Partial Wheel Covers
Less Engine RPM Control
Cold Start Up To -20%c
4 Wheel Anti-Lock Braking System
With Brake Only Traction Control
With Sngle.L/B Dvr/Dual L/B Pass.St
With Manual Clutch
With MPH/KMH Speedometer
With Radio Pre-Equipment Pack 1
6000CD RDS EON
With Front Fog Lamps
With Load Compartment Lamp
With Manual Headlamp Levelling
