OBD Tool and Laptop Software
Postby StevenMurray » Sun Apr 19, 2015 4:08 pm
Can someone recommend a tried and tested ODB solution? Something that will reliably allow me to check fault codes (and clear them?).
Preferable on the low price end of the scale.
Many thanks in advance. :)
2002 MK6 LWB 90ps 2.4 TDDi Minibus
Duck Tape, for stuff that moves and shouldn't
WD40, for stuff that doesn't move and should..
StevenMurray
Re: OBD Tool and Laptop Software
Postby ake » Sun Apr 19, 2015 7:56 pm
A Chinese vcm clone gives you full ford ids.
Postby StevenMurray » Sun Apr 19, 2015 11:38 pm
ake wrote:A Chinese vcm clone gives you full ford ids.
Cheers. Can you advise on a link for that?
StevenMurray
Postby wexican » Tue Apr 21, 2015 11:17 pm
This is the one I just got.
http://www.obdtool.co.uk/wholesale/best ... -tool.html
Does everything apparently :D
I've just read the codes so far!
wexican
Postby bazw » Sun Apr 26, 2015 10:02 pm
I got this one has been a great help to me and works on loads of cars and trucks
http://www.ebay.co.uk/itm/111578209852? ... EBIDX%3AIT
Delphi clone
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby knighty1981 » Sun Apr 26, 2015 11:24 pm
wexican wrote:This is the one I just got.
couldn't resist it with a recommendation like that, just bought one :-)
knighty1981
Postby MK7 user » Mon Apr 27, 2015 11:13 pm
StevenMurray wrote:Can someone recommend a tried and tested ODB solution? Something that will reliably allow me to check fault codes (and clear them?).
You won't get a lower price than a FREE download. :D
I don't have a Mk6 but the sample picture shows a 2000 MY Mk6. 8)
No Squire, not just any van....it has to be a Mk7 (VM.1) :D
MK7 user
Location: Grim HQ in the parish of Aston Nr the Great Hall
Postby StevenMurray » Tue May 12, 2015 11:59 am
OK, I bought a cheap ELM Interface off fleabay and seem to be unable to get it to work. It comes with a CD with all the drivers and a copy of ForScan. After installing the drivers and the software on my laptop then connecting the ELM Interface, I'm unable to get a connection to the van. The ELM Interface shows up as Com4 in the Device Manager and the PC says the device is operating correctly, but the Forscan software can't see it.. I've taken some screenshots as below:
The unit I've bought is this one:
http://www.ebay.co.uk/itm/181331159561? ... EBIDX%3AIT
I'm just concerned at this point as to whether my van is ODBII or just ODBI. Could that be the problem? But if that's the case, shouldn't the software still recognise the ELM, just not connect to the van???
StevenMurray
Postby MK7 user » Tue May 12, 2015 4:07 pm
This is an ELM 327 adapter....
The F-Super you have has either been modified to replicate an ELM or it won't work with FORScan. :(
In Device Manager set the "bits per second" to 38400.
In FORScan, set the "COM Port" to AUTO, and "Baud Rate" to AUTO....it should check all open ports for a recognised adapter.
Bear in mind that you are unlikely to receive a "genuine" ELM chip in anything you buy off gay-bay....they are all made in China clones....fake....not the real deal. :shock:
FORScan is looking for an adapter that reports as an ELM, regardless of it being a genuine ELM chip or not. Is there any other software on the disc? the adapter you have should work with Formidable....another FREE download just not as good as FORScan. :D
EDIT: No, your Mk6 is NOT OBDII compliant, FORScan has been compiled to use an ELM on a Mk6....F-Super uses Formidable on a Mk6.
MK7 user
Postby StevenMurray » Tue May 12, 2015 6:33 pm
IT WORKS!!!!
The seller sent me a replacement in case it was the ELM. Changed the unit out and now have access to the van with ForScan. :) Happy Days. :)
Thanks everyone. :)
StevenMurray
Postby MK7 user » Wed May 13, 2015 11:45 am
Happy days :D
MK7 user
Postby Fakir » Mon Nov 27, 2017 6:51 pm
Hi guys!
Its an old post, but you never know!
Im new here.
I have exactly the same question, what ODB shall I buy?
I have a 2006 december MK7, with 85k miles,bought it 2 months ago, and was in service every week, luckily its under warranty for 6 months. BUT, I just want to check by myself at home whats wrong with it, to check the codes.
Any cheap sollution?
Thanks If you read it, and reply
Fakir
Postby knobby1 » Wed Nov 29, 2017 11:57 pm
I just got one of these:
https://www.ebay.com.au/itm/Mazda-Ford- ... 2749.l2649
Comes with the latest Forscan and the relevant drivers on a CD too....works on my Mk7....did a pump, pilot and injector learn on it yesterday...no issues at all.
Also have one of these which works well:
https://www.ebay.com.au/itm/USB-Modifie ... 2749.l2649
