Mk6 spare wheel - how to wind down the carrier???
Postby firewalker » Sun Apr 19, 2015 8:51 pm
How does this thing wind down???
I took out the anti-theft bolt in the rear valance and shone a torch inside to see what I'm dealing with and am still none the wiser.
I don't have the wheelnut brace just the jack and winder in the toolkit, and I understand it is the brace I need to wind it down but surely something else can be used until I get my hands on one?
Thanks in advance...
firewalker
Re: Mk6 spare wheel - how to wind down the carrier???
Postby El transito » Sun Apr 19, 2015 9:07 pm
firewalker wrote:How does this thing wind down???
The other end of the wheel brace has a flat taper on it much like a very big screwdriver, you need something that shape, a cold chisel with some grips would do it if it's the right taper. Anti-Clock lets the wheel down.
El transito
Postby firewalker » Sun Apr 19, 2015 9:58 pm
Many thanks - I have tried a Mk5 brace with has a plastic tipped flat end like a big screwdriver which sounds like what you describe but still no joy.
From what I could see there is no slot? More like a circular rim to a hole with what appears to be the flat end end of something metal filling it.
Any help appreciated, thank you.
firewalker
Postby ake » Wed Apr 22, 2015 6:25 pm
Mk 5 brace has a square end, not flat, it's totally different.
MK 6 and 7 is like a giant flat head screwdriver about 20mm wide and 5 mm thick
You could use a piece of flat bar, bend it at about 500mm to create a handle
Postby firewalker » Thu Apr 23, 2015 6:59 pm
Thanks Ake, I have tried the flat end of a crowbar but it doesn't seem to hook up with anything.
Looking into the hole it looks like something is sealing the thing off! Clean and metal looking, I wondered if it sprung in under pressure but not being able to see in there when trying to insert things not designed for the job doesn't help.
I may try to get something together to the dimensions you have given may thanks for that.
firewalker
Postby rikki19 » Thu Apr 23, 2015 8:01 pm
Which hole are you looking into ?
Mk 6 2.3L petrol 2001 MWB T330 275K
Mitsubishi WA Express 2.4L
Proton Satria GTI 2003
rikki19
Postby Brains_transit » Thu Apr 23, 2015 9:43 pm
Have you opened the door and removed the security bolt that blocks the hole
Brains_transit
Postby firewalker » Fri Apr 24, 2015 11:38 am
The vertical security bolt is removed and what I see through the hole facing me looks a lot like this:
http://www.evolutionparts.co.uk/new--ford-transit-spare-wheel-carrier-double-rear-wheels-00-06-1689817-8416-p.asp
3rd pic from the left. Looks like a lock of some sort?
Thanks for the feedback!!!
firewalker
Postby Brains_transit » Fri Apr 24, 2015 12:26 pm
Just unbolt it from the rear crossmember theres 3 or 4 bolts holding it on the back then you can get a better look at it
Brains_transit
Postby firewalker » Sun Apr 26, 2015 8:25 pm
I've figured out that a hexagonal socket is needed, if anyone has one that they could give me the dimensions for so I can just get some hexagonal bar or a bolt head to it I'd be very grateful!
firewalker
Postby Brains_transit » Tue Apr 28, 2015 11:53 am
Find a bolt then clamp it in a drill with forward and reverse
Brains_transit
