by suziquee » Sat May 09, 2015 1:27 am
Can anybody tell me what the component is underneath the radiator water tank on a 2005 VJ Transit ASM it is sitting on the bodywork, it is about 2 inches square and is grey plastic. I thought that it may have been the ASM clutch fluid pump but I may be wrong. This component has a motor/pump as it runs when I open the drivers door and won't stop till I close the door or insert the ignition key and turn two stages. Hope you can help, Cheers.
