Cruise control
Cruise control
Postby marjers » Sun May 17, 2015 6:58 pm
Can anyone shed some light on the reason my cruise control only stays on for about 50 yards ,
I press on then set speed but it switches off by itself, :?:
Cheers
2010 mk7 2.4 350l rwd 100ps mwb hi-top
Tuned by vantuner 115 eco
marjers
Re: Cruise control
Postby ake » Sun May 17, 2015 6:59 pm
Do you drive with your foot on the clutch pedal?
Re: Cruise control
Postby marjers » Sun May 17, 2015 7:01 pm
no take feet off all pedals,
its retro fit cruise ,but has been working fine for several months now ,
no loose wires all connections good :!:
marjers
Re: Cruise control
Postby AndyG » Sun May 17, 2015 10:34 pm
Check the sensitivity of your clutch and brake pedal switches :idea:
Re: Cruise control
Postby marjers » Tue May 19, 2015 4:43 pm
Have taken apart all switches on pedals and cleaned ,adjusted pedals so there is no play on switches , damn its still the same
doesnt cut out when accelerating only when you de-accelerate :?: weird and annoying
marjers
Re: Cruise control
Postby loot » Thu May 21, 2015 4:07 pm
When you say retrofit do you mean Ford oe fit or aftermarket cruise system?
Ids map here
loot
Re: Cruise control
Postby marjers » Thu May 21, 2015 6:48 pm
Im talking " How to add factory cruise by loot", re- checked all wires and connectons bcm and switches on wheel all seem ok,
does not switch off if i keep foot very lightly on throttle so its just accelerating ,maybe throttle pedal on way out??
marjers
Re: Cruise control
Postby loot » Thu May 21, 2015 8:20 pm
Can you get it on ids for a pedal test? :-)
Ids map here
loot
