blue estate wrote:Still air in system or the slave is crap
jizm wrote:blue estate wrote:Still air in system or the slave is crap
Definitely no air. Been pressure bled about 10 times now. We also clamped the hose and hydraulic pressure was spot on. Are aftermarket slaves poor too?
karl mcghee wrote: ot the clutch master cylinder is giving up mate best to change al the hydraulic system
jizm wrote:Ok I just spoke to the guy I got the gearbox off and it looks like it's had a solid flywheel conversion. The clutch I bought is for my standard solid flywheel. Could this be the issue?
karl mcghee wrote:jizm wrote:Ok I just spoke to the guy I got the gearbox off and it looks like it's had a solid flywheel conversion. The clutch I bought is for my standard solid flywheel. Could this be the issue?
no no no
jizm wrote:karl mcghee wrote:jizm wrote:Ok I just spoke to the guy I got the gearbox off and it looks like it's had a solid flywheel conversion. The clutch I bought is for my standard solid flywheel. Could this be the issue?
no no no
Ok Karl. Thanks.
So all the mk6 fwd boxes are the same?
The new box came off a 55 plate. Mine is 52.
