Mk 5 Transit 1999 AirCon Refrigerant Service Ports ***NB These are NOT Schrader Valves***
There's a distinct lack of online information about replacing the ball/spring refrigerant charging ports used by Fords of this period.
Even in expert forums in the USA, postings asking about leaking FORD high side/low side ports are often answered with advice to "just change the schrader valve". Having had a good look at the ports themselves while the pipework was off the vehicle, I'd originally decided that these were best left alone, and would probably seal OK with the caps on, since there is design information that states that whatever slight leakage from this ball/spring valve will be completely eliminated by the final cap. I'm now of a mind to change them after all, at the next opportunity.
I've had a look at the available online parts breakdown for this vintage of Aircon and there's no clear Ford part number. There's a few sources that list the following OEM replacements namely:
High side service port R134a M12x1.5 Ford/GM/Chrysler FJC2610
Low Side service port R134a M10x1.25 Ford/Jaguar FJC2608
These are also in the Four Seasons catalogue.
It would also seem that this port design is shared in focus/mondeo/etc of this vintage, but there's a shortage of online info to identify the exact item (or any source of replacements).
Is anyone prepared to share direct experience of replacing these ports? (I don't fancy trying to source new "old stock" replacement pipes so I think the best plan is to renew the ports)
Thanks for any info, and apologies for the lengthy post.
