http://m.ebay.co.uk/itm/FORD-FOCUS-TRAN ... nav=SEARCHWe get a couple of these a year probably, usually horn related, for 10 pounds it's worth trying it even without paying the 15-100 pounds diagnostics to tell you if it is that Lol.
These are not overly common to fail tbh bit make sure you read the installation instructions on the yellow sticker when fitting it.
Changing it isn't bad really the only bit that can piss you off is releasing the airbag clips.
56 350 2.2 130ps mk7 with 2 side doors
65 290 2.2 125ps custom with 2 side doors
Ids v86 licence + v86.04 update + xprog
hereIds map
here
