tye1963 wrote:Hi I own a 2012 ford transit i bought it second hand whilst still in warrenty I had a recall letter on 16/5/of this month and guess what 20 /5 It broke down in Bath Had to be recovered from Bath to Bideford Ford Dealer cost me £225 Dealer Now says the Pump has Gone and It Has Blown the Turbo Will ford put this right ? I have No Vehical for work at moment Van is in Bits In Garage Thanks in advance Tye
delboyginger wrote:hi, thanks for that, i'll try and follow it up and let you know the outcome, cheers, derek
ake wrote:delboyginger wrote:hi, thanks for that, i'll try and follow it up and let you know the outcome, cheers, derek
Corroded sumps are very very common on euro 5 transit, so have a good look at it first
boltondigger wrote:ake wrote:delboyginger wrote:hi, thanks for that, i'll try and follow it up and let you know the outcome, cheers, derek
why do they corrode so much ? i thought they usually were pretty thick steel.
Is it worth Waxoiling it?
Jvic28 wrote:Hi Folks,
Putting it out there. Anyone with a van within these build dates may have an urgent outstanding recall which you'll all be aware of after joining this forum.
01/10/2011 - 04/10/2013
If you're unsure and would like me to check get in touch.
If you're in Cardiff or the surrounding area with an outstanding recall let me know and I'll get it sorted.
Really friendly family run dealership (with Ford whispering in their ears to get this sorted ASAP - HA HA)
Moderators - If this post isn't allowed, please feel free to remove, no offence will be taken
