I had a loss of power on my van 2002 FWD model 260 2litre transit, i found metal filings in the fuel filter, so a new fuel injector pump was fitted, a full timing chain kit was also fitted as this was badly worn, a new fuel filter and full service, the fuel tank was taken off and cleaned out as were the flow and return pipes, the gate valve was checked ok, the turbo was checked ok, the cat on the exhaust was checked ok,the clutch and gearbox are ok, there are no noises or rattles from the engine, no smoke from the exhaust, it starts and sounds mint, no lights on the dashboard, it has been checked on a Modus diagnostic machine and no codes present, but after all this it still has no power it's as if the fuel is being restricted and this power loss is bad on any slight incline it loses speed fast,
I am trying to find a ford transit fault flow chart for a 2002 2 litre FWD
