by ned » Tue Feb 09, 2016 6:12 pm
How are you planning on painting rattle cans or spray gun, first and most important remove all rust, bare metal etch primer then take your time with normal primer fill and sand the areas so you have a nice smooth surface apply primer slowly building up the coats remember to light sand between coat, when your satisfied with the results its time for colour coats built up slowly and sanding between and finally clear coat again building up slowly then when dry use rubbing compound to shine up. This is not exact but a rough idea of the way I have done vans in the past.prep is everything so don't rush.
