Hi can any one help i have a Transit 350 crew cab 2.4D twin wheel RWD early 2006 mark 6 i think (its the one after the smily face). all started when i replace the wheel cylinders and was putting the brakes back together when i realised i could not wind the adjuster out far enough to gently rub the drum. I've tried generic new shoes and new drums but realised my old ones weren't worn that badly.
I have checked that i have the right adjuster though part numbers and i do.
Running a tape Measure across the fitted shoes and the adjuster wound right out i have 277mm, and the diameter of the new drums are 280mm
There's a good 20mm the adjuster can adjust which would bring the fitted shoes back down to 255/260mm.
All i can think is that there must be another size shoe out there for it , but i can't see any shoe sizes to choose from when search the shoe parts number
