Altransit wrote:I was hoping someone who actually knows would have answered your question, as my knowledge of these is all second hand from reading various posts on here
The 145 pump that you have, has much improved fuelling over the earlier pumps, and these, and the 146 pump are often sought out by folks needing a manual pump conversion on a turbo engine. It's probably the 'top of the range' when it comes to the VE Bosch units.
If you fit an earlier pump, it will almost certainly, adversely affect the performance that you had with the 145
